Toto w/ 10” rough
Kathryn
NJ
Hi! Renovating our hall bath and need a new toilet.
It’s a 10” rough so choices are limited...
Is Toto Drake the best option?
The showroom I went to recommended - CST776CEFG
Should I go with 1.28 or 1.6 GPF?
Thank you so much in advance!
Sincerely,
Someone who does not know anything about plumbing
Your Toto choices are limited in that price range. There are expensive skirted Toto choices for 10 inch too.
From your photo, if I am interpreting correctly, you might want to consider relocating the toilet paper holder. But certainly if your dispenser stays there, even the most ardent "over" person would be loading the roll "under".
1.28 or 1.6 GPF? If available, I would go with 1.6. I am not a pro. If I lived in a desert, I would go for 1.28. Both will work well.
The 776.10 bowl needs at least 9.5" to the wall and the standard 12" bowl needs 11.5" to the back wall.
Your molding at the wall extends into the room quite a ways, with the TOTO bowl being long where is meets the floor, it may be a bit tricking using the 10" bowl. It will probably work, even with the strange floor molding.
You will like the TOTO better than what you have been using. The bowl works well with 1.28 and with 1.6
index.php
