No Hub Cast Iron Fittings
JWT1010
Vancouver BC
I've taken a permit out to add 4pcs & 3pc bathrooms to our home. Both bathrooms are over a family room / bedroom so I bought cat iron No Hub fittings to reduce noise.
Most of the fitting have a ridge where the 2 sides of mold did not line up. The ridge can be removed/smoothed with a sanding disc. After sanding so some of the fittings still have a 1/64" wide line in the casting which I think may leak.
Would it be a good insurance plan to use a little silicone on all of the fittings just before putting the clamps on and torquing them?
JWT1010
Vancouver BC
GOOD fittings do NOT have that ridge.
The fitting are from Bibby, Tyler and AB&I.
There's not difference between 1 mfg. and another in the number that have ridges and those that don't. A few have been ground by the mfg. but then they missed the opposite side or the other end.
I was wondering if pro plumbers who know more go through the bins and take the best but that means 40-50% of the fittings are junk.
I dont sort them unless they are real bad , if it holds test it should be good.
you could touch it up with grinder.
JWT1010
Vancouver BC
I spoke with a friend of a friend this morning who does new apartment buildings. They do the same as you do. Most of what they do has easy access so it may take 10-30min to change a fitting.
In my case the joist are 12" OC so everything will be locked in by the joists. Changing a fitting would involve cutting pipe or taking things apart from the top down.
Here's a 2" fittings with a ridge that I can't see how a clamp would seal next to one I've sanded with an 80 grit flap wheel.
jwt1010, good plan I'd do that too on a job like that even a file to knock most of it off. you don't want water squirting out on your big screen.
JWT1010
Vancouver BC
Thank You
Decided to use some 100% silicone sealant too. I don't want it to be like the fittings I see weeping when I have to park in an underground parking lot.
A file or grinder would likely be faster than sanding and less likely to leave a gouge.
JWT1010
Vancouver BC
It takes about 20-40 sec / fitting with a 5" x 80 grit flap wheel on a 4 1/2"grinder
I'm sanding twice as many 2" fittings than 3" & 4" fittings
