cavalierchamp
Does this cast iron drain fitting look rusted through to ya'll? The oxidation seems to be in a dripping shape, which suggests to me there's a leak and I should fix while I have the wall open during bathroom remodel.
If so, what's the proper repair? Cut out the iron fitting and replace with PVC/ABS fitting, reattaching to iron pipe with steel reinforced no-hub fittings? And use steel hangers to make sure the weight of the remaining iron vent pipe is supported from wood framing above?
Appreciate any pro tips you may have!
Pic #1
Pic #2
Pic #3
Pic #1
Pic #2
Pic #3
