Steveo
Texas
Old angle valve failed so I had to replace it and needed to replace the supply line as well - the old supply line was part of the valve.
First time doing any of this kind of work and wondering if the supply line I installed is the wrong length. I had to put a lot of pressure on the line to make it bend to line up with the openings. Probably should have angled the valve toward the toilet but again this is my first time trying.
Would a longer supply line be better and take some of the stress off the connections - or since it isn’t leaking don’t mess with it?
Before (White line) and after (ss braided line) pictures attached.
Helper Dave
Wisconsin
It's likely fine. You could angle the stop towards the toilet to have the supply bend a little less aggressively if you really feel the need to change it, though.
Steveo
Texas
Thanks! I had thought about that but I had a hell of a time getting the compression fitting to sit and not leak so I’m more than a little hesitant to try and move it. Unless it’s necessary to prevent a catastrophic failure in the future I probably shouldn’t test my luck!
Looks good! I sometimes turn angle stop at a position that alows a better bend like closer to 3 oclock . but I think its fine!
Steveo
Texas
Appreciate you taking a look! After I tightened up the compression nut I wondered if that would have been a bit better. But it isn't leaking and so far so good - so not gonna fix what isn't broken. Sometimes my "fixes" are worse than just leaving it alone ... learning to just leave it alone :) Thanks again!
