Single handle Moen (shower only) has slow leak from pipe out of wall
Caccaco
Atlanta
I am using very technical terms here but have pictures to better explain it. Our Moen shower fixture is leaking. I took off the shower head to see if it leaks directly from the wall and it does:
Its a slow but very steady drip and over the past couple of weeks has been increasing in speed. I no longer thing it's just water left over from a shower as it will still be dripping hours later.
This is what the handle part looks like as well as the Moen logo.
So where do I go from here to stop this?
Is the 1200 and 1225 interchangable? Home Depot right down the road has one I can go pick up tomorrow if so.
Got the brass one yesterday and replaced it, simple job and it does appear to have stopped the leak, so thanks!
One thing I noticed when I took it apart while following the guides is that there were three of these metal washers/trim things inside:
When I put it all back together I only used one and left these two out. Any idea on why this would have been like this?
So me just putting all of the extras in a drawer shouldn't matter much, right?
Its been two weeks now, no leaks detected from the shower head itself.
If you save all the extra parts in a place you can actually find them later you will never need them. If however you toss them or place them in a "safe" place, you will need them.
