Simple hose faucet repair turns ugly :(
Heracles
Pennsylvania
Hi guys
Just my luck - my hose faucet / bib was leaking. After looking up some diy I swung at it today. Went so well starting off -
Removed the inner shaft exposing the worn out gasket- noticed was a beveled gasket - tried a smaller one that matched still got the leaks - then went up to 1/2 which still leaked
Then as I was removing again thinking it's probably the Oring gasket of the hand valve - look what came out - I can't tell if the shaft broke leaving the gasket side in - or disassembled somehow
The good news - it's stuck in there at the closed position so no water is running out the hose faucet
It leads into the basement bathroom - there is no seperate hand valve for it
So I have no idea what to do now
here are some pics
What does the view from the bathroom look like? Is there an access panel, or what?
Heracles
Pennsylvania
It leads to the back wall of my finished 1/2 bath basement bathroom -
I guess it sounds like I need to cut open drywall and get to it - ?
If so while at it so you think I need. To install a shut off valve for the hose faucet ?
What a disaster then again I guess I'm lucky it didn't break in the open position
Cutting into a drywall wall seems better than cutting into a tile wall.
I wonder if Smooky suspects you could just replace parts in the existing unit. I don't know myself.
If my other hose bib was the same, and the back of that one was accessible, I would take a look at that one.
Quarterball
Smooky is correct, it is a Prier unit. Looks like the stem separated from the acme threaded portion where the seat washer is located. If you can get the stem to temporarily re-connect (epoxy?) to the lower section that remains in the sillcock, you may be able to extract that part & replace the stem unit vs. replace the sillcock. Check out the parts breakdown for part # C-134 at www.prier.com and this will make more sense.
Cacher_Chick
Test, Don't Guess!
By the time you find the correct replacement parts and make a proper repair, most of us would have replaced the complete assembly, ate lunch, took a nap, and moved on to the next job. :)
Heracles
Pennsylvania
That sounds like a good idea quarterball
I'll try to decide if I should try to fish it out with epoxy and rebuild the shaft
Or if I should be brazen like cacher cut open drywall to access and replace entire silock
My thinking is that if the unit screws into a solidly mounted piece, you may be able to unscrew the other one from outside. Then screw in the new one. I am not a plumber, and I have not done this.
That can go wrong, so if it does not work as hoped, you would then immediately tear into the bathroom wall and use the access to replace replace the valve.
Heracles
Pennsylvania
Yea thought of that - if it goes wrong then go to plan b in wall
Bad thing I can't get to it now wonder if I should try to epoxy the shaft
CountryBumkin
Active Member
Orlando, FL
You can try epoxy - but I'll bet you it won't work. There is just not enough surface area to get the bonding strength you need, and no way to clean the end that broke off in the fixture. Plus I think it would be almost impossible to not epoxy the shaft to the body of the faucet.
Best case, you will just waste a little time. Since you'll be replacing the faucet anyways, IMO, might as well give it try. Good Luck
