Replacing Shower Pan
Erik B
NY
Recently purchased a new home and after using the shower for 2 weeks, we realized the shower pan began to leak. The pan was not set correctly, and had soft spots causing it to bend. The plastic drain finally cracked and water began to make its way underneath the pan.
I am having some difficulty understanding why I cannot remove the first row of tile in my shower, remove the existing shower pan, reinstall a new shower pan (correctly), and reinstall first row of tile? I would be purchasing the same exact pan, so dimensions will be identical.
Also, this is a basement shower.
We have some spare tile, so matching new with existing is not an issue here..
Erik B
NY
I havent considered that. Looks like that product would work well here. Thank you.
Im not sure how I would have access to place anything under the pan to stiffen?
Also, there is some water currently in between the pan and concrete subfloor. I suppose that would dry out of the course of a few days? No reason to worry about mold growth?
Movement is you biggest problem. Most instruction sheets suggest embedding the pan in mortar to prevent flexing but it can also fix out of level as well.
It looks like the pan is cracked, but if a replacement drain has a surface wide enough, you may get a good seal. The pan will crack again if you don't add support underneath. That's much easier to do just before you set the pan down into piles of mortar. They'll compress and spread out, allowing you to level it at the same time.
Dj2
California
Recently purchase new home?
- Contact the builder and have them replace the pan and do it right.
Sylvan
Still learning
New York
I totally agree having the plumber or GC contact the plumber and have then replace it
Once a third party touches it all warranties are off
Last one who attempts any repair is now fully responsible
