Shower help please is hubby right?
DIYMissus
Ontario, Canada
Hi we're installing a new shower pan and need to move the drain. Hubby says we should connect to the old trap I think we should remove it and run a new drain tying into the existing line.
Also can the shower pan be secured to the nailer strips in the ICF wall?
Thanks in advance.
Cynthia
John Gayewski
Iowa
Where does that horizontal pipe go? It's piped incorrectly and should be repiped anyway.
If that horizontal pipe is also a drain for the lavatory then you just need to change the fitting type. If it's a dry vent it needs reconfigured.
I don't see how you would keep the existing trap, and feed it from the red circle location.
DIYMissus
Ontario, Canada
Thanks for your help It's a dry vent - I marked it. The drain goes directly to the main sewer line .
wwhitney
Berkeley, CA
So a dry vent needs to come off the drain vertically, and isn't allowed to go horizontal until 6" above the fixture flood rim. Therefore your shower vent needs to be redone, in the context of which relocating your shower trap is a small matter.
Cheers, Wayne
DIYMissus
Ontario, Canada
Cheers, Wayne
Thank you I'm looking at some proper schematics. Since this is an ICF house I see why they didn't run the vent up an exterior wall.
John Gayewski
Iowa
It doesn't need to be an exterior wall. Any wall will do. You need to start with a location you can run a dry vent or a location where you can cut into the bathroom group piping to convert to a horizontal wet vent configuration.
DIYMissus
Ontario, Canada
I'm sorry I wasn't clear i should have said the logical place would have been to run the vent up inside the exterior wall directly behind the shower drain . Converting to a wet vent is beyond my current skill level tbh. I think I see a straightforward way to keep it as a dry vent I will post a picture tomorrow Thanks again.
A wet vent is not as complex as it sounds. It is pretty much joining the lavatory drain to the trap arm, which wet vents the shower.
