Jammed sink stopper...do I have to saw???
Lyn Wolford
Burleson, Texas
I got frustrated and craaaaaammmmmmed the stopper of my bathroom sink down into the drain assembly and wow did it work! It is suuuuuppppper stuck now and moving the up/down thingy does nothing...and is even harder than it was before. Grrrrr.
Believe I have what I need to put in a new one, but how do I get this one out?
Good news is that the little bar doohickey through which you thread the up/downer is broken (don't look at me) so I can pull that out and get rid of that obstacle. So can I, in theory, somehow turn the whole darn thing, stopper and all??
I should have listened to my mother....something about patience.
Dj2
California
You get it out by disassembling the drain set from the trap to the sink.
Then you re-assemble it again, but if it's damaged get a new drain set.
Not sure? don't know how? no time to do it? got no tools? ---- call a friendly plumber.
P.S. Don't forget to put a big enough bowl under the trap to catch water.
Michael Young
North Carolina
Yeah - call a friendly plumber. Cuz we're such a friendly bunch.
If you want to try to save the existing stuff, you might be able to just drop the P-trap. You may have to pull the actuator rod stuff, depending on clearance. Shove a rod/dowel up there to try to raise the stopper.
Maybe you could rectify the reason that the stopper jammed with cleaning or sandin
You might be able to use some repair kit for the broken rod. Try this search on a site with plumbings stuff: drain rod
Come to think of it, replacing the whole assembly sounds easier now that I think about it. However lifting the stopper out could let you use the lavatory until you get the assembly replaced.
