Connecting tub drain on concrete pad
Count Krunk
Orlando FL
Hello Everyone,
I am stumped here.
My house was built in 1985 in Central Florida. We are renovating the master bath and I have run into this issue.
The drain coming out of the house appears to be 1.5" with a 1.5" tubular conversion piece on it. I want to use a schedule 40 PVC 1.5" tub drain kit on it. I need the kit tee to sit pretty much exactly where this fitting is. There is not enough room to convert it. How can I remedy this? Is the solution to use 1.5" tubular instead of standard PVC for the tub drain? If that is the case would something this product work? https://www.amazon.com/Watco-Manufacturing-500-LT-PVC-CP-1-5-Inch-Overflow/dp/B005FJ92B4
The tubular drain
1.5" PVC tub drain tee
where it needs to sit to work with the tub
Thank you for your help!
Ryan Symons
Dihydrogen monoxide specialist
Either use tubular or dig up the trap and replace it if there's no room to use a coupling.
Some as above, if you dig that out some you might be able to add a coupling or perhaps the trap too.
The threaded male adapter there is for the tubular waste and overflow.
Count Krunk
Orlando FL
thanks guys. I won't be digging up the concrete anymore than it is so tubular it is! I learned today that there is 1.5" and 1.5" tubular and they are not the same.
