Installing a Flexible Tub Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by trombonemann, Apr 7, 2021.
  1. trombonemann
    trombonemann New Member
    Apr 7, 2021
    Marietta, GA
    I have a Watco Flexible Drain that I am installing on a bathtub renovation. Need to move drain over to accommodate larger tub. The Schedule 40 PVC I need to connect it to had a slip-joint with a brass drain assembly previously. The Watco has a female connection that a 1 1/2 Schedule 40 PVC pipe would fit. Can I install two slip joints to connect these using 1 1/2" under sink PVC to connect Schedule 40 PVC?
  2. Tuttles Revenge
    Tuttles Revenge In the Trades
    Oct 15, 2014
    What model number waste kit did you get? I typically wouldn't trasnsition from sch 40 plastic to tubular/slip joint downstream.. What material is the trap made from?
Similar Threads: Installing Flexible
Shower & Bathtub Forum & Blog Installing a MAAX Shower Base Mar 5, 2021
Shower & Bathtub Forum & Blog Installing an acrylic shower pan Feb 16, 2021
Shower & Bathtub Forum & Blog Question about installing alcove bathtub May 9, 2020
Shower & Bathtub Forum & Blog Installing a direct drain for tub Feb 22, 2020
Shower & Bathtub Forum & Blog Installing Moen transfer valve Model 3372 Nov 8, 2019
