If you're plugging up normal bowls with your BM's, then installing product limited to a 2" trapway isn't solving the problem, is it?INTRO: I'm going with the self-purchase and self-install of Caroma Caroma Stanley Smart II. Plumber was over for non-related issue, and saw Caroma in boxes. He tried to talk me into Gerber Viper 1.6 or American Standard Edgemere 1.28. But their 2'" traps ruled them out.
Plumber touted their 3" flush valve and he modifies the tank to hold more water for a "better" flush. Also said low flush toilets are geared for PVC pipes, while mine are circa 1938 cast iron with likely corrosion and thus not a smooth surface. He never heard of Caroma - and I believe more interested in what happens AFTER the BM is past the toilet into the waste pipes.
QUESTION: The opening at bottom of bowl (inside the bowl, not where wax ring goes) appears to be the same size as my current toilet. Measurement was by shoving my fist into each opening (I know, I know). Do you ever "see" the BM not make it into that opening? Sometimes mine are so large they get stuck in the bowl. I guess that's just an issue that the Caroma can't solve.
Terry, thanks for the reply, especially as you were kind enough to repeat yourself (again) for me. I tried to steer my plumber to think about the clog in the toilet, not the issue of "movement" through the drain pipe. He touted a toilet that he uses at home, but refused to let me try that product out at his house.If you're plugging up normal bowls with your BM's, then installing product limited to a 2" trapway isn't solving the problem, is it?
I've sold a few hundred of the Caroma bowls, mainly to those with your issue.
MaP test works with 3/4" x 4" stools. If you need to flush something like a 2" stool, then the Carama is what you should be looking at.
If you're worried about water in the tank, the Carama has buttons at the top, hold one down until the entire tank drains. That's more like 3 gallons.
You've got this.Terry, thanks for the reply, especially as you were kind enough to repeat yourself (again) for me. I tried to steer my plumber to think about the clog in the toilet, not the issue of "movement" through the drain pipe. He touted a toilet that he uses at home, but refused to let me try that product out at his house.
I had never heard of Caroma for this issue until discovering this website, and am grateful to have found about the brand and the insight (both the good and bad). I am zeroing in on theYou've got this.
I almost was wondering if he was going to offer clear toilets on a weekly basis for you to back up his belief that all toilets handled large BM's the same.![]()
It's rare that I ever have to service a Caroma. They hold up well.If anyone has any insight on whether a handle or buttons might be preferable on this model, I would appreciate your insight.
Review of Caroma Stanley Smart II after one month. As one of the one percent, the Caroma earns 5 stars!
The end to constant plunging is such a relief. No longer is "taking a dump" a pain in the ass.
Vast majority of times, one flush and done! Once in a while a second flush is needed. And rarely, need to hold down the flush button for a longer flush. Every time one flush didn't do the trick, the "stuff" did not move at all on the first flush. Sort of it it was stuck to the bowl with some in the trap hole. Never had an issue with the "stuff" actually getting stuck in the trap.
All in all, I never thought a toilet could be so satisfying.![]()
This may help others... I bought the Kohler pressure assist for my 1st house based on suggestions from this forum. I am totally happy with it. Made the plunger obsolete. At the time I bought the Kohler, I was single with no kids. The noise didn't bother me. BMs the size of Loui vill slugers go down with ease.
In my girlfriends house she has El cheapo toilets and they get stopped up about once a week. She doesn't like the noise of the Kohler in my house. It looks like I'm going to have to go with Carmona and just deal with the cleaning.
I have a Caroma Sydney Smart II toilet. I have a healthy diet and get tons of fiber. Sorry to be gross but I have large BMs similar to what you described and they flush no problem. Caroma is the toilet you are probably looking for. They have a 4 inch trapway and can handle large amounts of waste.I'm so pleased to find this thread.
Longstanding Problem:
(The efficiency experts all want to cite how many golf balls or whatever... they need to measure with Polish kielbasy [yes, that's the plural of kielbasa].)
Our yoga center; rest rooms have total nine toilets. People here are into healthy diets, high fiber and ruffage, not much animal protein. Result is generous extrusions (largest maybe 2 1/2" x 15", no exaggeration) which create a continual maintenance headache and burning sinuses.
My surmise is that the problem is (a) the size and curve of the trap and then, assuming the kielbasa can get beyond that, (b) the smallest diameter from there to wherever it's going. (Is that reasonable?) The toilets under $300 (x 9, Yikes) I've checked out online at Home Depot, Lowes, and plumbing supply houses have traps max 2 3/8". I've looked at macerators, but the trap is still the limitation.
Suggestions other than relocation?
i Have a Toto, I am 6'5" 215 lbs, still clog my Toto about 2-3x a month. I found putting dish soap in and working it down in works b/c dish soap is an emulsifier. I just want a toilet with a passageway about 15-20% bigger..or one of those government toilets with no tank, just a flush lever. push the handle down and everything goes even made my tie flutter lol.If your son is in the 1% or so with a medical problem and produces long, hard stools, probably the best toilet for that is made by Caroma which has the largest trapway of any readily available toilet. Don't confuse flapper valve size with trapway size. It's not only the diameter of the trapway that makes a difference, it's how it is shaped. Toilets that try to make sharp turns are very tough on longer, harder inputs! The Toto line has a much nicer pathway than most out there.
Do not confuse suggested list prices with actual street prices on Toto toilets. For a fair estimate of what is a good price, check out Terry's storefront. While he does not sell outside of his area (he does not ship), you can use that as a negotiation price locally. Many models that work quite well from Toto are a lot less than that $500 pricetag.
