Best non-Caroma pressure-assisted toilet?
peppers
Kissimmee, FL
My father is on meds that are causing constipation and massive BMs. We have had plumbers out to his home multiple times over the past month to clear clogs and install new toilets that I thought would "save the day." The plumbers suggested we get "pressure-assisted toilets." I didn't realize there was a difference between vacuum-assisted and pressure-assisted toilets, and in my defense, when I googled "pressure-assisted toilets," the first toilet that appeared was Home Depot's Glacier Bay Power Flush (which turned out to be "vacuum-assisted"). The plumbers installed these Glacier Bay toilets and did not even seem to notice they were the wrong kind either. When we were still having issues with the BMs not going down, the plumbers came back and said that these Glacier Bay toilets were not the answer. Thankfully, Home Depot will take them back, but I obviously need to find new toilets. I have read on this forum that the Caroma toilets are great, but it looks like there would be a great deal of shipping costs to get them here to Florida. The plumbers are to put together a quote for me, but I wanted to do my own research to find out if there is a decent model out there from Home Depot or Lowe's that would suffice. https://www.lowes.com/pd/KOHLER-Hig...2-Piece-Toilet-12-in-Rough-In-Size/1000066035 is one I found - not sure if this is one that would be recommended? Thanks in advance for your help, as this issue has caused my dad great embarrassment and stress.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I can assure you that the Kohler Highline is, along with equal by American Standard will perform as good as any other pressure assist out there. We always use them in commercial rest rooms for trouble-free results. Sorry about your dad…I know of which you speak.
Peterson
Active Member
PA
That Kohler Highline Pressure Assist will do the trick. They are a very powerful toilet and have an excellent flush.
peppers
Kissimmee, FL
Thank you both so VERY much - I really appreciate it. Wish I had found this forum before I got my dad the wrong vacuum-assisted toilets. Live and learn! God bless!
