Urgent, Please Help! Island Drain/vent Installed Correctly?
Jerry Tang
California
Yes. he has it right now. :)
Terry, I see he used a T for the vent which was supposed to be a Y. Is that an issue? Also looks like he soldered the copper pipes instead of brazing under ground, do you think it's ok?
Cool Blue Harley
One Dumb Plumber
San Francisco, CA
Technically both of the tees, the one for the foot vent and the one on its back are required to be wye and eigth bends. That being said, it will probably work just fine. However, copper tubing installed under a concrete slab is required to be brazed, as you noted. I see you're in California, that would be California Plumbing Code 609.3 (2). Don't you have plumbing inspectors?
Jerry Tang
California
I don't have an inspector. I am trying to have him correct it by moving the pipes up from the ground, so there's no connections underground, or at least braze it instead of solder it. It does not have space for a Wye as if installed wye the horizontal vent pipe might not have the 1/4" upward.
Cool Blue Harley
One Dumb Plumber
San Francisco, CA
The waste and vent will be fine. Better off with a tee and 1/4 inch per foot on the foot vent than wye branch fittings and a flat foot vent that is consideted a drain. The copper should be brazed. What is your question?
Jerry Tang
California
If we braze the copper pipes, what fitting/connection material to use? I know the pipes should be L type.
Jerry Tang
California
plumbing experts, please advise. I am thinking to put dirt over the copper pipe fittings before covering with concrete to avoid concrete movement to break the copper pipes. Do you think would it solve the problem by doing this along with brazing the fittings?
