PerryNotMason
hi all,
I'm installing a new small bathroom in my attic - the space is awkward and small, and my main question is about using space wisely.
I'm located in Portland, oregon for code purposes.
I intend on having a 3" toilet drain, as well as a lav sink and a shower in the new bathroom.
new bathroom is above an old 1923 kitchen i am remodeling, so i am placing any pipes in the walls/ceiling now while i have stud bays open/am working on the ceiling.
2 x 8 joists, 2 x4 walls in the house, so finding room for anything is complicated.
Here is my kitchen wall where most of the magic
happens. It's real tricky.
There is a 2" cast iron kitchen sink drain directly below where i am working, but a 3"/4" is either on the other side of the house or in the slab or outside.
all three will have an fixtures in attic will have an AAV - they will be installed against a knee wall and so i can pop a vent that can draw air from that cavity no problem.
but finding a way to run drains has been really challenging, and the only feasible way i can make the toilet work is to drop through the ceiling of the room above, go around the top plate, then out through the soffit. I found a way to make that work, with only a small elbow jut out i can disguise.
plan on running the 3" drain along the outside of the house, and then connecting it to the drain that connects to the city in the spring when i dig up the yard, as that pipe is less than 4 feet away from the corner of the house I am working on. New sewer connection cam in 3 years ago.
Here is how the drain gets outside through the kitchen wall - photo taken after the one above.
Anyway - here is my question:
Can i join the 2" drain from the lav+shower with the 3" toilet after the toilet's AAV and before the pipe turns downward to drop through the ceiling? With a wye or santee, as long as I can get slope up to the lav and shower?
Or do i have to run a separate 2" pipe through the wall into the basement (i don't want to run it outside) and link up with the 2" old pipe from the kitchen?
I could do that to the left of the window, but i still have to get through the ceiling and I don't want to drill a hole through the double top plate for a 2" pipe as it is the exterior wall and rather load bearing.
I could also run the 2" pipe through a different kitchen wall near where the shower is, but the connection to a drain in the basement is much more complicated as there is ducting and electrical conduit and a chimney i'd have to work around in the basement where the pipe comes out of the wall.
Any advice on how to run the drain pipe would be helpful.
thanks a lot for your time.
