Push button sink drain stuck closed
adulting
California
I have a push button bathroom sink drain that is stuck down. (way down, about 1/4" below the outer ring) I can not get it to release, and can not get it to unscrew while depressed. The drain and sink are only about 4 months old. Is there a way to fix this? Or do I need to replace the whole drain assembly?
There is currently no water in the sink.
Are you saying to open at the P-trap and push from beneath? Is there access to the stem from beneath? (Sorry, I'm DIY...trying to avoid having a plumber come over, with all this virus stuff going on.)
Maybe no water in the sink, but there will be water in the p-trap. It's designed to always have water which acts as a seal against sewer gas from entering your home.
You want a place to catch that water when the p-trap is removed.
You may be able to push from below with something thin like a long screwdriver.
