Problem with Moen 1225 Shower Replacement - Stop Tube
pwtnet
Ottawa, Canada
I'm fairly experienced replacing Moen 1225 cartridges on my sinks. But I'm having a problem with the one on my shower. After I pull off the handle and cover plate, I can't get the stop tube out. It seems to be embedded in a plastic housing. None of the online vids show one of these plastic covers in them (you just see the valve in the hole in the shower.
If I manipulate the stop tube, the whole plastic assembly moves with it. Any suggestions?
I've attached a photo. The problem seems to be with the reddish piece.
pwtnet
Ottawa, Canada
Oh - this would have all been installed in the late 1980's. Haven't had the stop tube out in all that time!
Is that kerf in the shower surround at about the 4:30 position something that you did recently?
The plastic behind is used to prevent the tile from being too close to the valve, normally tossed after tiling. It's also used to hold the valve when used with a fiberglass enclosure. The stop tube will pull straight out and part of the plastic tile guard may need to be cut to lift up the retainer clip for the cartridge.
If I knew what lay under there, which I think you may know, I would consider taking a hole saw and clearing out a space.
To use a hole saw, such as a 4 inch hole saw, you drill a hole into a piece of scrap plywood. You remove the pilot drill. You have somebody hold that plywood firmly over where you want to cut, and drill. The plywood keeps the hole saw from skittering.
pwtnet
Ottawa, Canada
Thanks Terry. You're absolutely right. I wiggled and pulled and out it finally came. Shower's now working like new! Half of DIY is knowing "how hard CAN I pull on this without breaking something". And you answered it.
Thanks again!
