Within the last few months, we had our old jet pump replaced with a submersible. Our pressures shot up, and everything has been good. The current issue is we have a plumbing nightmare. Mismatched lines (1/2" main to 3/8 on hot line) and we lose pressure since everything is basically shared with 1/2" copper mains. We also will be adding a 2nd bathroom upstairs, so our plumbing will not support the usage. My plan initially was to remove all of the old copper, keep all the stubs at the fixtures and put in PEX. Currently the line after the pressure tank is 3/4" PEX. I initially wanted to do 1" main for a trunk then go 1/2" off the main for each fixture, but then I saw inline manifolds and a home run system. If I'm thinking right, even if a 3/4 PEX line entered a manifold, I still would see pressure loss if 2 or more fixtures were being used correct? I did a rough drawing of the downstairs of our home (it's a very old Victorian) to show the layout and where the water heater, pressure tank and water softener sit in the basement. At this point, I'm not sure what would be the best layout and size for our home. The 2nd bathroom would go above the den in the photo. I'm not afraid to do the plumbing (I've done 90 percent of the remodels here), but I'm not sure what would be the most efficient layout for usage (family of 5). Any help would be appreciated!
