Joshua Sturm
Hi All,
During Hurricane Harvey my home flooded, and the pressure tank on my water well floated, and broke the well head, casing, etc. I have a packer well system, with a 3/4 hp horizontal pump, that has a 2" casing, and a 1 1/4" inner pipe. I repaired the broken casing with a 2" coupler and some pipe. On the inner pipe I ordered an "inside coupling" which glues up inside of the pipe instead of slipping around it. I wasn't ready for the water since the house was still being repaired, so I let the glue sit for about 2 weeks before trying to make sure it all worked.
Yesterday, (Saturday 2/10/2018), I primed the pump, turned the pump on, and was getting water pumping into my pressure tank. I noticed the pressure was "jumpy", only hovering around 10 psi. I messed with it for while until I ran out of daylight and came back today to try again. This is when my trouble started. Today I had no water going in my tank, so I tried to prime again, but it kept taking water, so I finally stopped after 4 gallon jugs. I took the adapter that converts it from a 2 pipe to a packer system off, and found that where I used the inner coupling, it blew off the rest of the inner pipe inside the casing. 2 feet from the coupling up to where it is threaded into the adapter is still there, but the inner pipe is somewhere inside my well casing.
This well is an 86 foot well, with PVC casing and PVC inner pipe. I can see down the well about 8 feet or so until the water level, but no pipe. I had a 15' steel pole I used to see if I could feel the PVC, but no luck.
I have 2 questions for y'all on this,
1st) Is there anyway to fish the pipe out, or try to push it further down the well to get it cleared out of the bottom of the well?
2) Could I just use the the casing as the suction for the pump, and not worry about the inner pipe?
2a) If I can do this, would the adapter I have now work? Or would I need another type?
I have included pics of adapter and well type. The 2nd pic is not my system but it shows the adapter and inner pipe better than what I could, ( since my inner pipe is somewhere between here and 86 feet down lol)
Thanks in advance for any help on this issue
