Easy Answer: Water Flow?
Jay Beth
New York
I want water to flow in two different directions, all from one source, kind of like a T-type ball valve. However, I don't want to spend excess money on T-type ball valves that have the ability to alter water flow by the handle. Instead, what I would like specifically is a pipe/tube fitting that takes in water from the top, and then allows it to flow to the side and straight down. What do you recommend I use?
Source
v
--------> Water Flow
v
Water Flow
I am a bit confused about what you mean?
I expect all of us may have been confused by your description. I thought my description was clear. I was trying to best-guess what you were trying to describe.
So how about you make the diagram, or explain how my interpretation of your diagram does not meet your needs.
Jay Beth
New York
Water flows from source (like from a well, or from a faucet) to this fitting:
v
Water is split in two directions - - - - - - - - > Water flows here
v
And water flows here
Jay Beth
New York
Or maybe, even better: Could you explain to me how this fitting works:
That is a PEX tee. Water source is connected to any one of the three ports (holes). Water comes out of the other two ports, which are connected to two uses of water.
Jay Beth
New York
So will it do this:
