Hi!
We had to pull out our half-bath vanity to replace the wood floor below it and I realized that the faucet has a permanent supply line which cannot be replaced.
I installed the faucet 7 years ago and am sure that the supply line has been reattached 2-3 times.
Is it ok to reuse a rubber gasket compression supply line? Can the rubber gasket be swapped out? If not, any solutions that might work to ensure that it does not fail?
Thank you.
Thank you.
