We took a very small 1949 bathroom, gutted it and added three feet to it. We hired professionals for plumbing but it was a bumpy road with them. We go to use the tub for the first time and it wouldn’t drain. There was a MINUTE amount of water draining but my husband had to take a shop vac to the tub to get the water out it was draining so slowly.
Here’s what we/plumbers did:
-We completely capped and moved the vanity to the old tub location.
-The tub was moved into the new space created when we moved the wall. This meant adding a 3 ft section of drain pipe to the original.
- The plumbing failed inspection at first because the drain pipe didn’t angle towards the stack (stack was not moved from its original location).
- They “fixed” it but it still didn’t pass so we, aka my husband, did what the inspectors told us needed to be done.
-we did dump two pitchers of water down the tub after the instal with no draining problems. This was also done prior to new flooring being installed just to be sure.
- we kept the tub completely covered during reno, tile, grout, Sheetrock, etc.
The problem:
- The tub drain seems to be fine with small bursts, less than 30 sec of water.
- we filled the tub for our kids first bath in the tub. At the end it starts to drain for maybe 2 seconds then stops.
- you can depress the stopper and reingage it and it will drain for 2 seconds and stop again.
- the sink is on the same line and there is a vent (see pic) between the two u joints. If you fill the sink and drain it, it does fine but you do get some back flow into the tub. (My husband says this could be due to the T join instead of a Y used due to space issues)
-toilet has been functioning fine for the past 2 weeks, same with the sink.
Any ideas of what could be our problem?
My husband has tried to plunger the tub, hot water treatment, and is going to snake it tomorrow.
My questions are: can it be a clog? can it be the drain pipe still not angled toward the stack right? Is the vent not installed in the right place?
Sorry I don’t have a better pic but this is all I have showing the plumbing. Please say I don’t need to rip up my two week old marble floor...
The problem:
