Bond ABS and brass together
Jackson882
OKC
I have a freestanding bathtub with ABS waste and overflow and I need help connecting a brass tailpiece to this. What kind of cement will bond with these two materials
Jackson882
OKC
Take a pic of what you are trying to do, they make a slip joint connection for this. No glue
This is not my bathtub but it is the exact setup I need. My waste and overflow looks exactly the same as the photo, as well as the brass tailpiece
You can't glue ABS to brass. You can use either a slip joint nut and washer or they also make a Rapid Connect for hidden connections.
Why do you have an ABS tub waste and overflow and a brass tailpiece? You may want to also change out the p-trap there.
Jackson882
OKC
I purchased a OS&B brand hidden connection kit just like the one in the photo you posted however my kit came with a brass tailpiece.
How about a picture 800 pixels or less of your tub drain then.
The chrome tube is the same diameter as the brass. It's just fancier looking.
