JHL
Greetings everyone.
I have a house originally constructed in the 1950's in Southern California. There is a shower valve that is leaking out the stem that I want to replace.
I am fairly handy and want to tackle this myself. After reviewing available replacement valves at the local Ace store I pulled the trim off the offending part in my house and tried to identify it. Attached are the photos I took.
It appears from these photos that removal is fairly straightforward, attach socket and back the valve out. I am concerned about the shape of the valve that can be seen deeper in the wall, against the base. It also appears to have a much larger hexagonal shape that maybe I need to use instead of the smaller diameter hexagonal shape on the surface close to the access.
Also, I don't see anything like this guy at the store or even online. I don't want to shut off the water to the house and tear into it and be left with some oddball thing that cannot be replaced. Can anyone help with identification of this valve ?
Thanks in advance.
Thanks in advance.
