sigrid
We have, what I think it's the original two piece toilet from when the house was built in 1930.
The tank leaks - we've had the guts replaced, a plumber was here for over an hour, but it continues to leak - somehow the rubber stopper doesn't fall properly into the opening so unless we adjust by hand, it just continues to fill. What's weird is that sometimes it work right five or six times in a row (closes and doesn't leak) - and then for some unknown reason, it doesn't work again. Even if it does fill, it seems there is a small leak as every so often I can hear the water filling into the tank.
We've looked at replacement toilets - the problem is that the
- distance from the wall to the bathtub in the room is only 50"
- the current toilet is 25" in depth (measured from the wall) so it protrudes half the distance to the tub wall
- the new toilets we have found are all 5" longer - i.e. they would end at 30" - leaving only 20" between the end of the seat and the wall of the tub, which is really quite short
- most of the tanks are about 2" from the wall too, so not attached to the wall leaving a gap - I don't know what condition the tile wall is behind the tank
- we also require a 14" rough-in
Is it possible to only replace the tank on the wall (who would make one?)
Are there ANY SUGGESTIONS, SOLUTIONS you or your experts might come up with.
I am hesitant to spend another $100+ to have yet another plumber come out to take a look at the insides only not to be able to fix them AGAIN.....
So anything you could suggest would be most helpful.
Thanks for your much anticipated response.
