After doing all my research (this is a great site!), I just bought a Toto Drake (CST744S) locally. I unpacked it and looked at the instructions, then went to download the instructions because I inevitably lose paper instructions. To my surprise, I found a much newer set of instructions at totousa.com, dated 4/08 -- the ones in the box were dated 6/05.
When I read through the newer instructions, I found that the tank mounting instructions are different in the way you install the mounting bolts and the newer instruction make a point about the tank making "three points of contact" with the base. The newer diagram shows three tabs on the base where the contact should be, tabs that my base does not have. See page 2 of: http://admin.totousa.com/Product Downloads/0GU008Z-5, 1.6 GPF TOILETS, IM, V.01.pdf
So, the questions are:
-Did I buy a Drake that's been sitting in a warehouse for a few years?
-If they changed the tank mounting, did they change anything else that would actually make it worthwhile to find a more-recently manufactured unit?
Thanks in advance for the help.
