Wet bar sink drain installation / venting with diagrams
Discussion in 'Canadian Plumbing Code Questions' started by crank73, Feb 18, 2021.
  1. crank73
    crank73 New Member
    Feb 18, 2021
    Ontario, Canada
    Good day all
    I hope this isn’t seen as a dumb question. The answer is likely buried within various different post and my basic venting theory is just that, basic and code requirements is nil.
    I am simply trying to tie a wet bar sink drain into plumbing my builder roughed in for a future laundry tub (no washing machine).
    Diagrams below show what is currently roughed in for the laundry sink that would be installed right next to and attached to the rough in via p trap. The waste line goes to a grinder pump pit which is vented.
    My questions are
    1. Can I simply tie my wet bar sink drain into the same vertical waste pipe that my laundry sink is draining into using proper slope? It would likely tie into the vertical pipe below where the laundry tub drain currently is.
    2. Is the vertical vent pipe being a good 10 ft away from bar sink too far?
    3. Do I need some sort of horizontal venting for the wet bar sink that would tie into the vertical vent pipe which goes outside?
    Any advice is appreciated.
    Thanks in advance.
    683D260C-365C-42E5-BDCA-1C2191143DAD.jpeg B6B86B78-1E44-42BB-BA99-F28E806180C4.jpeg
  2. Terry
    Aug 17, 2004
    A bar sink can't be wet vented with a laundry sink. It will also need to be vented, and those vents can tie together.
  4. crank73
    crank73 New Member
    Feb 18, 2021
    Ontario, Canada
    Thanks for the quick reply Terry. So confirm then that either of these 2 options would work?
    4B85ADCF-40F3-4032-8B33-EDF6A1D8855B.jpeg DB02BF93-9908-4124-BAB8-60FD9DF12193.jpeg
Similar Threads: sink drain
Canadian Plumbing Code Questions One sink two drains. Jun 26, 2020
Canadian Plumbing Code Questions Canadian Plumbing question ( indirect drain & new garage sink) Jul 19, 2017
Canadian Plumbing Code Questions Bubbles and slow draining kitchen sink Jul 3, 2017
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
