Hello all,
When soldering 3/4" copper pipe to connect a water heater.
1. Should you open the nearest water valve to allow the hot air to travel up to avoid blowing out the solder from the joints?
2. Should you also open the nearest faucet, both hot and cold to further allow the hot air from soldering a way out?
3. When soldering next to black steel gas lines should they be covered with sheet metal 26 gauge to protect from the flame possibly coming in contact with the gas?
4. How do you clean the excess flux off the pipes after you are done soldering?
5. What are the most important newbie mistakes to avoid when connecting a water heater for the first time with soldering the copper pipes?
Thank you all in advance.
