Brandon Kelling
Recently re-did the plumbing on my hot water heater because it was done with pex all the way to the nipple and that is a code violation. In doing this changeout I could not get the new compression type fittings to make a good seal with the plastic heat trap inside the pipes. They were causing a drip on both sides....after removing them the compression fitting made a good seal.... Will this be okay ? Picture below
