Hot Water Heater Install
dfreysinger
Colorado
I recently purchase a double wide mobile home with a gas hot water heater. I was a maintenance electrician for a couple of decades, so I am replacing it with an electric hot water heater. It is in a closet that is accessed from the outside of the home.
I am replacing the original poly b with pex throughout the home. I am using copper manifolds located in closets with no connectors in the floor or walls. I know this is overkill, but I have particle board subfloors in much of the home.
I plan to run the hot and cold lines of the water heater up the wall of a closet on the heated side of an insulated wall that divides the water heater closet from the inside closet. My home is at 10,000 ft in Colorado, so avoiding frozen water lines is a priority. My current hot water heater does not have an expansion tank, so I am planning to add one. Is there a maximum distance from the hot water heater? I would like to install it on the heated side of the wall. The current system has heat tape on all of the lines inside the water heater closet. I am trying to keep heat tape to a minimum to avoid high electric bills.
Fitter30
Peace valley missouri
That's ok to mount it inside the trailer. Match the air pressure in the ex tank with water pressure. Can get a gauge with a hose bib thread on line or at a hardware store
Sarg
Enjoy Learning
Upstate New York
I would also suggest a remote thermometer for the area of concern. I worried for years about freezing pipes running heat tape all winter ............... only to find the area of concern never dropped below 40 degrees until it was below zero outside.
