Vent off shower drain trap arm
Girafdaniels
KC
The attached is a photo of a proposed plumbing layout underneath a shower.
I’d like to pull a short run of horizontal vent off the pictured san tee, attaching a 90 directly on top of it and tying it into an existing vertical vent about a foot away. After the san tee, the drain line quickly drops below the weir, so this is why I’m needing to put the vent take off so close.
Any concerns with this set up?
Thanks very much for your advice.
I'm not a fan of the vent fitting above the p-trap. Should be a medium 90 and not a vent 90.
Most codes require a wye or combo fitting if you pulling a vent off the horizontal now.
Girafdaniels
KC
Thank you for the insight. I’ll steer clear of the vent 90 and do a combo.
wwhitney
Berkeley, CA
Depending on the location of the vent pipe you need to connect to, a wye and two smaller bends could work and would be less total bend than a combo and a medium 90. Up to 6" above the shower flood rim, the vent needs to be plumbed as a drain. And it's supposed to stay vertical (meaning up to 45 degrees off true vertical) if possible.
Cheers, Wayne
Girafdaniels
KC
Cheers, Wayne
Thank you, Wayne. Could work well that way and the drain line consideration is appreciated.
