I have a couple of obstructions I need to work around to connect a new shower to the horizontal drain line so I need to offset the P-trap. The shower is a guest shower and will only rarely be used so I don't anticipate issues with a buildup of odor due to accumulation of debris and I'll make sure the p-trap doesn't run dry.
Is the layout pictured below OK? I can't go under the duct because I don't have enough height to connect to the horizontal drain line. Per the 2018 IPC, the depth of the drop to the weir is under 24" and the distance from the center line of the shower inlet to the P-trap inlet is under 30".
NOTE: This is just a dry run. In the photo, it looks like the horizontal drain is going uphill. I'll make sure there is proper slope when gluing up.
Thanks for your advice!
