Tub wont fit. 3/4" too long.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by plumber69, Aug 13, 2019.
  1. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    There must have been a flaw in the tub, because its 60 3/4 inches. There's an excess fiberglass build up on both lip ends. Like 1/2". What can I use to sand them down? Would a block and 80 grit sand paper work
  2. Terry
    Aug 17, 2004
    I ran into that before with an acrylic tub. It was never trimmed off at the factory, and yet they shipped it. I wound up trimming back the wood studs in the room to allow myself the fit it in the alcove. Then I had to go back and fir out the wall afterwards. Should I have sanded, or cut, or bitten off the extra that hadn't been factory cut? I wasn't sure I could cut it cleanly enough. I did wind up getting it set though.
  4. cjlambert
    cjlambert Red-Seal Licensed Plumber
    Jul 24, 2019
    Magician
    Toronto, Ontario, Canada
    My first inclination would be to contact the supplier/manufacturer and have them come to pick it up, while at the same time delivering a new tub that is actually the size that was originally ordered. If you aren't interested in waiting around, I would probably do what Terry suggested above and notch the studs with an oscillating multi-tool. Alternatively, you could use an angle grinder with a zip disk to chop off the excess, though doing this (or performing any kind of alteration of the fixture) would technically void the manufacturer's warranty.
  5. Terry
    Aug 17, 2004
    Come to think of it, there was a second tub I installed that had the same issue again. We trimmed the studs on that one too. Same brand of tub.
    No, I won't say. I'm hoping it's a rare thing.
  6. jadnashua
    If you will need to cut off the tiling flange, you'll either need to notch the studs, or try to get a new one that is actually the right size! A belt sander would probably take off the excess fairly quickly.
    What is your actual opening size? They may have made it smaller to match the tub you had in there. They usually are slightly smaller than the 60" so that they can fit into that space without binding.
  7. plumber69
    Jun 20, 2014
    They sanded both ends down a bit, but still didn't fit. I notched out the framing and all went good.
Similar Threads: wont long
Plumbing Forum, Professional & DIY Advice Kitchen sink wont drain Jul 4, 2019
Plumbing Forum, Professional & DIY Advice HTP UFT80 wont reach set point temp Feb 18, 2018
Plumbing Forum, Professional & DIY Advice Pfister Single Handle for Kitchen Sink Wont Come Off!!! Oct 11, 2017
Plumbing Forum, Professional & DIY Advice Pump wont start after sitting idle for 30 years Feb 27, 2016
Plumbing Forum, Professional & DIY Advice Moen Roman Tub valve set installed. Cold wont turn off Feb 2, 2016
