I'm installing a toilet in a bathroom basement. The drain pipe is 4" and the flange is designed to fit inside it. I cut the drain pipe flush with the floor. I dry fit the flange about half way, pulled it out and primed/glued it back in only it wouldn't go all the way down. It sat about 1/2" off the floor and I couldn't get it to go any farther. I managed to get the first one out and went and got another one to try again and the same thing happened only this one bonded and i had to chisel it out.
What are my options to get this in and now that its primed and glued already do i sand that out and/or clean it up before I try again? Can I cut the end of the flange off a little? It seems like the drain pipe narrows a little bit farther in.
Thanks
Thanks
