hi...
tried searching and didn't find much... i have a takagi tankless water heater that was professionally installed a little less than a year ago and it is leaking... it started a slow leak about a few months ago but i thought it was the pressure relief valve... the leak slowly started getting worse and just this week as i took a closer look, the leak was coming from inside the unit...
so it finally broke today and gave a 111 error code... apparently that means there's ignition failure... so now what?
well, it turns out that makes sense because as i opened the water heater and removed the circuit board and disconnected and removed stuff, the leak was coming from the burner assembly... i tried removing the burner assembly but that was fruitless since i didn't want to have to tinker with all the gas parts...
any suggestions? also, how is takagi's customer service?
thanks very much...
thanks very much...
