Qwertyjjj
- Messages
- 260
- Reaction score
- 2
- Points
- 18
I am installing an electric water heater with drain pan on a 3rd floor apartment.
As I understand it, I need to install a floor drain or pipe the pan to the outside. It will be in a closet, which is around 15 feet away from the outside wall so it doesn't seem very easy to get a pipe to go to the outside and I would then have to connect the pipe from 3 floors up down to the ground.
Adding a floor drain isn't very easy either since I need to cut out some of the floor and try and find the pipe from the kitchen below floor level and plumb it in, add venting, and then use oil in the p trap to stop it drying out.
Any suggestions on the easiest way to install?
I could also put the water heater in the basement and pipe it up the the 3rd floor apartment but then I need to fish PEX through the inside walls.
