Sewer gas mystery
Lyn12
Springfield, Illinois
Help! Im sick from a year of breathing low level sewer gas in my house I purchased a year ago. Built 1965. Headaches, nausea, stomach ache and more. Google symptoms of sewer gas poisoning. I have it all. After Im away from the house after awhile Im ok. Ive had countless plumbers and sewer people out to find problem. No luck. Clean out put in outdoors. Sewer people cleaned from vent pipe from roof. I think they used a camera. Not sure. Plumbers smoked 3 times. Replaced wash machine trap under the concrete. Taped vents on roof as experiment. Smell got worse inside. Can smell outdoors also. My carpenter wont work anymore here. Bad sewer smell. Handyman quit. Bad smell. He feels sick here. One plumber smelled it when he got out of his truck from the street. Its outside too. Not many plumbers smell it as low level, so nothing is wrong...They put extensions on the vent pipe up to 3 feet tall for another experiment. No luck. The only time the fowl odor stopped was when the wash machine trap was being replaced. Once water run from machine to new pipes smell returned.
Floor drain trap and pipes under concrete is all I can think of thats left? Im in process of moving out. I cant take it anymore and no way to stop it. I took down the duct work and removed furnace as I thought this was the source. I hired someone to install a furnace. Coil nasty. He put the furnace in the basement and worked awhile. The next day he said he was coming to back to pick up his furnace. And away he and the furnace went. Then I hired two other hvac companies to rehang my old clean duct work and they quit because they were overcome and couldnt concentrate in the basement. So I have no heat. I have a carbon monoxide detector and had the gas company out. Had my blood tested to be sure it wasnt CO.
Do I need to jack hammer up the pipes and drain under the concrete and replace tap? Trap is not ever dry. I put water in it everyday. I measured water in basement trap before wash machine trap replaced and it was about 10" after about 6". Im moving next week because of the problem. I cant sell the house now.
Thanks for any suggestions
▶ Show quoted text
Cacher_Chick
Test, Don't Guess!
If every trap is full of water, there has to be a leak in the piping. The plumbing system can be sealed and pressure tested, but finding a leak may involve opening up walls and/or floors.
Smooky
North Carolina
The traps may stay full until you run the washing machine. If everything is not vented correctly and connected properly the traps can be siphoned. The washing machine drain may have been added some years after the house was built. Hopefully the repair that was done fixed any problem with the way the washer was trapped and vented. It is possible that the washer drain wet vents another fixture and could siphon the trap. Do you ever hear gurgling sounds at other drains when the washer is draining?
Master Plumber Mark
www.weilhammerplumbing.com
If you have a basement deep sewer, you can have a running trap installed in the concrete as the sewer leaves the building
by the final clean out..... they are called running traps and basically keep any and all sewer gas from the main from
even entering the home..... they used to be real popular back 75 years ago and in older parts of some eastern
cities you can run into them once in a while....
Lyn12
I never hear any gurgling.
I lived in a home that had a rusted through heat exchanger in the forced air furnace. I realized that our headaches were from the furnace.
We replaced it and it was back to normal again.
So you have pulled the furnace, and no relief. :(
The homecenters sell gas testing devices that may help you track that down, the gas emmissions.
https://www.homedepot.com/p/General-Tools-Pen-Style-Natural-Gas-Detector-PNG2000A/100651812
I have not tried this detector yet. Does anyone have a favorite that they like using?
Lyn12
http://www.homedepot.com/p/General-Tools-Pen-Style-Natural-Gas-Detector-PNG2000A/100651812
I have a sewer gas leak, not a natural gas leak. That has been checked by the gas company. No problem
Lyn12
What is a basement deep sewer? Sewer pipe deep under concrete? When clean out put in front yard it was deeper than usual and they had to hand dig after awhile. Running trap. What is involved in putting that in?
Lyn12
It was not from the furnace. The coil was nasty. It took me tearing out 2 bathrooms, furnace and duct work, clean out installed, mold removal only to figure out it was sewer gas.
Lyn12
A picture of the plumbing under your sinks might reveal some clues.
The only sink is in the gutted bathroom and a licensed plumber did the work. Plus its been smoked. So I doubt that has anything to do with sewer gas. I have gutted most of the house including walls and everything is 100% exposed because of sewer gas.
Smooky
North Carolina
OK great, that will make diagnosing the problem a lot easier if we can see everything.
Only one sink? That seems odd.
Master Plumber Mark
Well , I am sorry .....I just made an educated guess...
I am willing to bet that all of the plumbers that have dealt with
your problem have taken their money and ran.....fast.....
maybe I am wrong and you need to just re-plumb the house from the
street in with new PVC especially if you are really wanting to sell the house.....
good luck.
