Service weight rubber gasket leak
Ulbin3
New Jersey
Besides cutting it out and replacing it.
Does anybody have any tips or tricks to fix a service weight rubber gasket leak I have it up on test for the plumbing inspector and there is a slow drip coming out of one of the gaskets.
John Gayewski
Iowa
You could try using a chisel and beating the gasket into place. But your likley going to have to replace it.
Fitter30
Peace valley missouri
Gasket is pinched or cast has a problem. Needs to come apart. That plumbers epoxy that comes in two part stick might work to get it passed then fix it right.
Ulbin3
New Jersey
Can you post a picture?
I don't have a picture but it's a standard underground application 4" sw cast iron bell and spigot with ty seal gaskets.
I have a test up with 10' of head and one of the gaskets is slightly leaking .I normally work with PVC for under ground and the few times I have worked with sw ty seal we had to dig up and snap the pipe with position cutters then replace with new pipe and gasket and a no hub coupling on the other side.
I was just wondering if there was an easier way .
That's what
That's what I figured
Ulbin3
New Jersey
I'm probably going to fill it once more and if it leaks I'm cutting it out thanks
Tuttles Revenge
Hercules Griip on install will fix the leak. Even if it has imperfections in the rubber or cast
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Out here in some jurisdictions, the sewer inspectors (special division, not the plumbing/building dept.) don't even call for water testing. They require the sewer contractor provide video evidence that the entire line has no bellies throughout the run.
If the joints look "good", they wouldn't even care about a few miscreant drips.
Even when they did call for head testing, five ft. would have been normal in the past., never 10' for outdoor.
Drips are good for the aquifer anyway.
normally sewer test to lowest fixture height. basically floor level . Most inspectors aren't out to make trouble, but I never want them to spot a drip .
Ulbin3
New Jersey
Honestly my stand pipe is only about 5 and half feet tall.
its the height to lowest fixture . I guess if its outside in dirt a drop isnt going to hurt anything did he sighn the card?
Ulbin3
New Jersey
Yes he was in and out in 2 min.
Also on my second time replacing the rubber gasket and new pipe I felt a small nub inside the service wieght fitting. I got a hammer and chisel and it popped right off . No more leak.
