Replacing Crane Floor mount Back Outlet with Gerber MX-21-022
Anna B
ny
Has anyone replaced a Crane Flormont Back Outlet toilet (3930N, specs at: https://pdf4pro.com/download/flormont-round-front-back-outlet-toilet-249f0c.html) with a Gerber MX-21-022 model (specs at: https://xrefs0.plumbersstock.com/Gerber/MX-21-022.pdf)? The rough-in and other dimensions seem similar, but I'm not sure about the footprint. A plumber is coming to do some other work and said they can easily swap out the old one if I get a fitting new one, but I'm not sure if the Gerber MX-21-022 would require the tiles to be re-cut to fit its footprint. There is nothing wrong with the old one except that it is old....
Any thoughts would be appreciated.
Thanks,
Anna
Most toilets sit on top of the flooring.
The standard rough for a rear outlet is 4-1/4" high. I don't see a problem yet.
Anna B
ny
Terry, thanks so much for the quick response.
The old one's rough-in is 4-1/8". The replacement's rough-in is 4-1/4". I am assuming that in itself should be OK.
However, the old one currently sits in a groove cut out from the tiles for its specific footprint. If the new one's footprint is different and it doesn't fit into that groove but has to go on top of the tiles (the tile thickness is ~1/8"), it will be an even greater difference, right? (I'm not sure if I am overthinking this, but I really don't know much about toilet specs, and I have been told I cannot return the replacement if I buy it.)
