Gerber Maxwell leaking
mymartinfamily
Phoenix, Az United states
Hi, I’ve recently replaced an old toilet with a Gerber Maxwell 20-021.
I’ve two back to back toilets in my 1960 home. One old and one new. The plumber couldn’t get them to stop leaking, so he cut the copper flange and used two wax rings. Still leaking, my question is i want to replace the carrier in the wall but not sure which one i need?
Planning to replace the other old toilet as well to the Gerber Maxwell.
The carrier I think I found is watts icsa-121-d
Any help would be greatly appreciated!
BECplumbing
Plumbing Apprentice
Louisiana
You could try the Jay r smith 0544 carrier. You will need to get one with a double fitting for back to back toilets. Here is a link to ithttps://roofdrainexpress.com/smith-...er-closets-with-vertical-center-line-fittings when ordering it you will need to select the one with the double fitting
