I have read in several locations that you cannot connect a tub spout with a diverter to PEX. The explanation that is usually given is that the inside diameter of PEX+fittings is smaller than copper and it will result in water going up and leaking out of the shower head when the diverter is set to the tub spout.
However, I am planning to use valve that includes a setting to switch between the showerhead and the tub spout at the control unit, so my tub spout will not have a diverter. If this is the case, then should I still run copper to the tub spout or would PEX (using the 1/2" drop ear elbow) be OK?
