New pump pipe water color
Bryant Tart
North Carolina
I just drilled a new pump pipe in the ground since I was having water pressure with the previous well. I'm about 25 ft down and now have great water pressure but ran water till it cleared up but when pump cuts off it gets brownish orange in color then clears back up. Help??
Bryant Tart
North Carolina
Brownish orange is usually and iron bacteria.
That's what I was thinking but it clears up and I can cut pump off for a split second turn it back on and it pumps clear and then changes andeventually clears back up.Didnt know if i had a badstrainer or what
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Anytime you start and stop the pump you are stirring up the well and you will see what gets stirred up. A strainer is only going to get things that are large enough to strain.
Bryant Tart
North Carolina
So I guess the only option is too try a better water supply or will eventually wash out?
I would collect some colored water in a jar and see how it looks when it settles. I am not sure where I would go from there.
For the well, you could try pumping it dry at a high rate until you run out of water. Then shut down to let the well recover. See if that improves things faster.
