Black water after pump replaced
Rman
Master mechanic
northern NJ
My eight year old well pump died. Had the old pump pulled out from 300 ft and new goulds 3/4 hp 7gpm 240v pump installed into well same depth. Chlorinated well 3 gallons bleach
Ran water till smelled chlorine then left for 4 hours. Started well to flush and the dark black color of the water flowed for about 2 hours. Stopped well only produces 4gpm. Next day my BB filter was clogged when I tried to fill my water heater 50gal
Cleaned and replaced filter cartridge 5grains
Ran water again for about an hour put hose in bucket less black but not clear. Should I run water every day till clear? Don’t want to run out of water. I do have hard water and manganese but prior to pump replacement the BB filter and softener cleared up the water. Filter replacement was about every 3 months. Now 1 day and filter almost clogged.
Thanks
Bannerman
Ontario, Canada
In addition, what is the pH of the raw well water?
Chlorine has a hi pH value, so when pH is not reduced sufficiently, chlorine treatment will be less effective.
To increase effectiveness, the water pH will often require pre-treatment with white vinegar to lower the water pH to offset the pH rise that will occur due to the addition of chlorine.
Run your water for hours, but if you are concerned about running the well dry, keep an eye on it.
When I sanitize my well, I recirculate the water thru a washable/reusable 4.5 x 20 filter cartridge in a BB housing.
Rman
Master mechanic
northern NJ
I’ve only found disposable BB cartridges
At a cost of $11 each it’s getting expensive
If you could let me know where you got the reusable cartridges
Thanks
It takes me a lot more than that for sanitizing. I measure the chlorine ppm and the pH of the recirculating water. My method is more intense than most people use, and it is better to do it in warmer weather from a comfort point of view.
But using more chlorine and/or vinegar will not help your sediment problem. The sediment came because you stirred things up.
This is my sanitizing write-up:
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Just keep pumping. Pump wide open with no pressure and a 7 GPM pump will make 12 GPM. Turn it off as soon as the well pumps dry, let it recover for a while, and pump it again. Anything you don't get pumped out will end up clogging the filter.
