I'm tiling a shower and running into some issues, here's the situation:
Cast iron drain pipe is coming up at an angle. There's an 8" x 14" cutout in the slab around it. I can move it slightly by pushing on it, but not enough to make it plumb. I'd like to avoid getting down into the ground and so would like some opinions on using a flexible banded coupling- recommended or no? Also, what do y'all recommend in terms of filling in the cutout? Can I use sand/gravel or do I need to pour cement? If the latter is the case, then what do I wrap the pipe and coupling with to prevent corrosion?
All opinions much appreciated.
