MW6243046CEFG#01 TOTO Legato installation with pictures, including the SW3046T70 Washlet. TORNADO FLUSH® and CEFIONTECT® ceramic glaze.
This is one of my favorites and this one comes with the S500e Washlet. PREMIST of bowl before each use.
TOTO Legato with S500e, though you can also get the S550 too.
It comes with a standard 12" Rough Unifit adapter. It also works with a 10" and a 14" in case you have a different rough-in. I prefer the water supply at 7" to the left of center.
The bowl drops down on the adapter.
The Washlet comes with a THU6050 Base Plate
Which the Washlet slides into.
Connecting up the water to the toilet and the Washlet.
The THU6234 T Adaptor for the water supply to the Washlet. This fits on the bottom of the 7/8" fill valve and the supply line from the wall to the bottom. The Washlet uses the side outlet, sealing with an O-Ring.
Spec sheet
Spec sheet
