Jeff_Bathroom
Hi,
I won't bore you with the details, but in the master bath remodel I'm working on, I moved the wall behind the toilet forward the width of a two by four or about an inch and a half. I knew I'd be moving the
toilet drain as a result. I did not at the time think that would be a big deal, but I got a look at the drain
today. Everything is hooked into it...the shower drain and the double vanity sinks. It would be a royal pita to try to move all of that even the slightest distance.
I've seen those toilet connectors that are not straight down, but the drain part is offset at an angle for just such issues as I'm having.
Is that a good method to get around this problem and about how much lateral difference does one of those give me, distance-wise? I'm, guessing that someone would ask whether I've purchased the toilet yet and the answer is yes, otherwise I'd consider getting a toilet that could be closer to the wall.
I'd appreciate any insights.
Thanks.
Thanks.
