jrbe
Short version is I'm looking for a tub / shower diverter that contains .25% lead or less. Seems shower diverters are exempt from NSF 61 and prop 65 (not for drinking water.) If I'm wrong on that please correct me.
I'd be all for trying a polypropylene or polyethylene shower diverter if anyone makes them.
Long version is that we have well water that tested over limit on uranium, no lead in the initial test. There aren't great affordable options on removing uranium from drinking water. We ended up doing a whole house reverse osmosis system. Then getting the water tested it showed 6x the limit for lead and above limit for copper. We had copper piping with leaded solder. House was built in 1986.
I switched the whole house over to pex and replumbed copper into the furnace for 4' in and out with lead free solder and low lead mixing valve. Used john guest pp or pe fittings and Tees in accessible places (access doors in key distribution places) to avoid using brass pex Tees in walls (that whole dezincification failure thing and the ?? lead content in them.)
Water tested well below all levels, and this time LSI rating and Ryzner index were both tested/calculated. LSI was -4.6 and Ryzner is 15.6 S.U. TDS shows "001" on my meter and tested as <20mg/L. I realize I need to get the water less reactive. Planning on adding calcite and some magnesium to the ro water to help it be less reactive but want a diverter I dont have to worry about leaching lead into the water supply if the additives get low. Struggling with finding a low / no lead diverter and really want one with flow control.
