Zopkios
I’ve installed a Moen T2252EP and 2510 PosiTemp pressure balancing shower valve. Because I wasn’t happy with the shower flow rate, I removed the flow restrictor in the shower head.
So that’s fine now. But I am not pleased with flow rate for the tub. The tub spout is free and clear of any flow restrictor. There are no restrictive fittings between the tub spout and valve.
I disassembled all the supply lines to the 2510, checking in particular the one leading to the tub spout.
But I found no blockages anywhere.
I even removed the cartridge and separated tested the hot and cold flow. Although I didn’t measure the GPM when doing this, the water easily reached the other end of the tub, a very strong flow.
I don’t have low water pressure in the house. Water flow through the laundry tub faucet is very good as you would expect, there being no — flow restrictors.
The shower flow rate is good since I removed the flow restrictor.
Shut-off valves to the 2510 are lever type ball joint and are fully open.
I checked to see if I had the cold and hot reversed but they're correct.
I removed the chrome tub spout to be sure it wasn’t hampering the flow — no difference.
There isn’t an excess of elbows, just the ones shown in the photos.
Below the floor, the supply lines are each less than 10 feet from the main lines running through the basement. Both are 1/2 inch copper but the cold comes from a 3/4 inch copper line.
I measured the GPM — it is 3.5.
The PSI is 80.
So according to Moen, the GPM at that PSI should be at least 6.3 GPM.
Moen sent me a replacement 1222B cartridge — no difference.
I even removed the same cartridge from the shower downstairs and tried it — no difference.
With the shower downstairs, I tried it with the other cartridges and it works properly, same as the original one it it.
So what could be wrong — why am I getting just 3.5 GPM out of the tub spout?
The PSI is 80.
