Basically this is a spiral-type connection line that runs between the faucet and the retractable outletspout, if that makes sense -- it supplies the kitchen sink with water once it's been adjusted by the main knob, which is fed separately by each hot/cold water line.
Problem is that it's leaking pretty badly now, and these things appear to be made so that not even the connectors - the very rare and specialized conectors to each end of the unit, the main stem and the nozzle - can come off this lousy piece of leaky spiral steel flexi coil stock.
A replacement from delta costs bare minimum $87! this is a very minor amount of metal we're talking about here.
What I want to know is: can either this spiral hose stock be cut and coupled with some serous jerry rigging to circumvent the part that leaks? Clamps and sealant and whatnot? And could a different flex hose that connects to a standard kitchen knozzle be used to as a replacement if it were similarly jerry rigged to fit the connector at the base of the faucet? Currently this Delta model uses one of those snap methods that are very proprietary. I'm wondering if some right sized clamping using the highest pressure sorts of clamps would hold it in there and get the job done.
Please let me know if any of this makes enough sense to share some advice with me. Thank you for your time!
