Hello,
I live in Southeast Texas. I am replacing my old toilet with a new one, but ran into an issue when I removed the old toilet. It’s looks as though the original plumber made a makeshift offset flange by bending a thin lead pipe forward, slipping a toilet mounting ring around it, and then bending the metal around the ring to hold it down with minimal solder. The bend in the flange was so great the opening was only about 2 1/2” wide. Probably the cause of several clogs. The lead pipe also had too large cracks where it was bent.
Since I didn’t like how small the hole was or how the toilet mounting ring had become lose, I decide to cut out the bent and cracked parts of the lead pipe.
Now that I eliminated the mess, I don’t know where to go from here. Hopefully I didn’t screw everything up by cutting out the bad part of the pipe.
I have attached several pictures in hopes someone will be able to understand.
Please help... Any advice would be greatly appreciated.
Thanks Dean
P.s. In some of the photos you can see where the lead ties in to the pvc. You can also so lots of purple primer. How do you bond pvc with lead?
Thanks Dean
